jeffek
hi guys . this is one of my first posts so i figured i would make this thread even though there are a few others on tethering lol.
here is how to quickly and easily add native tethering and hotspot to metro zte zmax.
first you must be rooted or temp root. (you dont need r/w permissons)
next install xposed framework. (google. it) install through recovery !!
then install the xtether module . it is for motorolla but dont worry just install it.
activate module (check the box)
go to your apn settings
make sure apn protocol is ipv4 not 6
go to apn type and add ,dun at the end . mine says something like default,mms,etc,dun
save and reboot phone
native hotspot and usb tethering should work fine now
confirmed working on metro butternoob rom !!
jeff.
jeff.
