enlarged wallpaper - distorted
Boopolo
Member
Hi,
Whenever i try to set a pic for the wallpaper, after adjusting the green square no matter how big or small, the pic that appears in the background is a lot zoomed in and blurry. This is the same whether it is my own pic or downloaded from places like zedge etc.
Howdo i fix this? Thanks
you have to be careful not to tap in the square. You need to very carefully touch the edge of teh box and drag it to the max size you can. If you do it wrong, you will actually see it zoom in. It is indeed very fidley
My suggestion would be to get 'wallpaper set and save'. Its the best thing ive used, one because it sets the wallpaper (niceeee) but more importantly it removes the colour banding that plagues android in regards to wallpaper.
