Help Enter Car Mode by choice?
RBEmerson
Is there a way to force the DINC2 into car mode? AFAIK, only the act of stuffing the DINC2 into the right sort of dock does the job - is there a widget or shortcut to force car mode?
Thanks! Odd, though, that there's no shortcut, widget, etc. associated with Car panel. Or at least I haven't found it. But then, I didn't think about the search, either. :o
if you install Multicon, it allows creation of 4 icons in the space normally filled by one.
I tried it, and found that you can select "Car Panel" as an icon. The problem is, once you're in car panel mode, I couldn't figure out how to get OUT of it lol!
thanks! outside of multicon, I don't see another way to create a shortcut (funny that USA on multicon's menu, but not the stock one).
