Help enter key
mlbgamer
When texting with the keyboard, when I hit enter how do I make it do a page break (skip a line like enter does on the computer) instead of sending the text?
Also, is there a way to cancel a sending text?
try pressing Alt+Enter
I dont think you can cancel it.
chompSMS (free on the market) allows you to customize how you want your enter key to act...or well...two choices: act as an enter key or a send key
and I don't think you can cancel a text either...it sends it too fast
Yeah, you can't cancel. On a feature phone or non-android Verizon phone you have that little mailbox thing saying "sending" and you can press end and cancel during that, but not on Android.
You just have to press caps den quickly press the enter key and it shud work it worked 4 me hope this helps u guys and ladies =)
