Help Enterance swipe quesion
This maybe a stupid questions but i'm going to ask here because i'm sick of looking.
Anyhow the question is, is there anyway to remove the swipe across the screen when entering the phone after pushing the top button. Reason i'm asking is I would rather have the puzzle lock as it's a bit more secure as this is primarily a business phone. So instead of going through double the movements can I remove the first one?
I looked quite a bit but never found how to remove this one. I'm sure I looked right over it if it's possible many time.
This is not a direct answer ... I did something a little different ...
I installed the NO Lock app and put a widget on my home screen.
This bypasses both locks when in "unlock". When I want ot have it secured I hit the widget and it changes to "loock".
No Lock is the best app of this time that I have found.
... Thom
... Thom
switch pro widget does this too, and also includes a lot of other toggles like brightness, wifi, ONE-CLICK gps, etc...
Yes ... I used Switch Pro for about a year. It has a problem. If you power off and power on you must swipe to gain access and then go to Switch Pro and toggle the swipe off.
No Lock remembers how the toggle is set across a power off/power on. If it was unlocked when you come up you will skip over the initial swipe requirement.
No Lock can have a simple widget on the screen that tells you the current state. Click it and it changes states.
I paid for Switch Pro and convertede to the free No Lock.
... Thom
