Help Epic interface looks like 2.0?
Instead of being the Samsung interface, it changed to what looks like a 2.0 interface. I looked at any way to change it back, and the device says 2.1 is still installed....help?
Go to settings and then applications and click manage applications. Click the menu button and filter to all. After that scroll down to either Home or TWLauncer and click it. There should be an option in there to clear defaults, click it and press the home button and it will give you a choice between Home, TwLauncer and any other launcher you have installed. I'm assuming you accidentally switched to the Android Home launcher.
