S sjtimkojr Newbie Oct 1, 2010 #1 Is there any way to see what's on your SD card while it is still mounted in phone?? I can't remember what I downloaded to this card...
Kelmar Done by choice Oct 1, 2010 #2 You can use the app "my files" that is already on the phone to check the SD card (assuming you have the Epic). There are also a TON of apps on the market that will do this as well such as Astro (for if you have the Moment as listed in your profile). Welcome aboard! Thank you for posting in the correct forum
