Help Epic SD Fail?
epicDroid
So i plug my phone into the computer all the time and i can connect via usb but now i cant connect anymore to my PC. When i go to click connect to pc via usb it just sits there when i click it!! Any solutuons!!?!???
Try.....
A different USB port (the front ports on desktops are notoriously bad for connecting to the SD card), try a different USB cable (if possible, sometimes the one from the factory is junk), try a different computer (sometimes drivers screw up and you need to use another computer, nother good idea.. uninstall and re-install the phone drivers)
