Help EQ that works wen on phone calls.
I am looking for an EQ app that lets you adjust the curve of the sound of the person calling you. Wither you are on the handset, speaker, or Bluetooth.
I am hard of hearing and it helps to adjust some of the frequencies.
I have not found a EQ app that works on phone calls.
Anyone know of one?
My phone is an Unrooted LG volt on Boost Mobile.
Again, you're going to need root. :/ ViperFX (not on play store) has settings for all that, but I don't know if it applies specifically to calls or just media.
@Boostermike, ViperFX applies it's equalizer settings system wide and if you combine it with gravitybox you can add 15 volume steps to your system volume, you need to have root to do this. I wrote a how to on it here : http://androidforums.com/threads/how-to-set-up-viperfx-beats-audio-for-the-volt.894382/ in gravitybox which is an xposed module you can activate HD calling as well for better clarity too.
