Hey guys and gals,
I have been wondering about my signal on my SGS 2 as it's been up and down like a yo yo, and in some instances I get 0 bars and then it goes up on its own. This is whether im set on 2G or 3G or both, and has been getting on my nerves.
Add to the time without signal being quite high, I thought i'd try and work out the issue.
Well it seems that, if i'm on GSM only for example, the phone will switch randomly between GPRS or EDGE, even though I have network traffic turned off.
Whenever it switches between GPRS and EDGE, my reception goes from whatever bars it was on, down to 0, then back up to full. It does this often, and is annoying lol.
On 3G it does exactly the same, but i'm guessing between UTMS and HSPDA.
I tried searching before coming on and found nothing.
Is it possible this is hammering battery life? And affecting whether I have a signal (time without a signal) and can it be addressed?
Anyway hope this helps anyone with the same annoying issues.
Biff.
Biff.
