Help Ereader issues
gerbera_1
I just bought the Flytouch 3. Was very excited when I got it... but have had problem after problem. There has been a glitch with the ereader and it wont open up any files. How do I do this?
At least the ereader itself will open to the library - which it wouldnt do a couple of days ago... only had it for a week now... very disappointed... would love some help to get me to be enthusiastic again.
Do a search in the Google Market app for 'eBook' or 'eBook Reader' and you will find many alternatives.
I am currently using Aldiko and Adobe pdf Reader neither of which is perfect but both are usable; as they have different strengths and weaknesses I use them both.
Your best bet might be to download a few, try them out, keep the ones you like and delete the others. Most of them are free so all it will cost you is a little time.
Hope this helps...
