Yes, I had it. I fixed mine by going in and checking the word completion & spell checking for the compact qwerty. Typed the word "I'm", then I went and removed the check from spell check in the settings. Seems to work now.
Ok, one thing I just noticed with 2.1v3, I added a FOLDER on my home page called E-Mail, however, when I open the Folder and go to add my various e-mail progams in the folder, it states that there in no room on my home page to add a program, however, the folder is empty...any ideas?
I've rebooted and deleted the folder and re-added the folder, but still the same error.
Thanks!
A friend installed the 2.1 firmware on my Eris for me back in March. The build number is 2.26.605.2. After scanning through all these messages is sounds like I need build 2.26.605.4 or 2.36.605.1 to fix some of my phone's issues. Any suggestions as to which I should try? I've learned to deal with everything but I'd really like to see the html pics in my gmail so that's my main interest in updating. Thanks!
Hey Caddy, shouldn't you do an edit to the first post for fixes and just say "install v3"!
While I don't know Caddy personally, from what I've seen of his posts I do not think is a habitual liar. v3 while better than leak two still has some, imo, bugs that need to be corrected before pushing to the masses.
off the top of my head are:
plug in headphones while playing mp3's in the stock player and it continually skips through the songs (also noticed on slacker as well)
camera doesn't shut down properly, and will suck the battery dry in a matter of an hour or two.
Then the stock message app not displaying the proper number of unread (17 in the list of fixes) is not fixed either.
But the phone works!!!
I can't tell you how many times i was on the phone with someone and due to the lag and me hitting the contact 2x it put the person on hold and attempted to call them again.
Thanks! Are you running that version now & is it pretty smooth? I'm not a "tech savvy" as a lot of people on here but I think I can read directions & install it. Another thought: Since the Incredible just came out with 2.1, I'm thinking most of the bugs have been worked out. My husband got this phone last week but I'm curious as to what the build number is for that phone. I'll check when I see him later. That's what we would all eventually want on our Eris with the OTA, right?You should definitely go with the newer version, 2.36.605.1 or "leak 3" because it finally fixes the HTML embedded pictures in Gmail.
Since I was on 1.5, and through all the leaks up to v3, I have been happy as a clam listening to podcasts and having phone calls through my cars bluetooth stereo. I have never experienced any problems... until now.
Once I got v3 I have had a recurring bluetooth issue, see below:
When listening to a podcast, or having a phone conversation, audio is working fine through the car stereo. In as short a time as 3 minutes and as long a time as 11 minutes, the phone will stop transmitting audio to the stereo - but it thinks it still is. My car shows that the bluetooth is still connected (via an icon) and the podcast or person I am talking to on the phone keep going like nothings happened. The phone still shows a good connection, but no audio is being played.
I've done factory resets and whatnot but the fact that it is not application specific makes me believe it is a new issue with v3 of the leak. Anyone else experience this issue?
although i lost root... i am very happy about having images back in gmail! everything else is running smoothly for me as well with v3! (so far)
Why didn't you just wait for a v3 ROM for root? The leak hasn't even been out a week. Not worth losing root indefinitely, IMO.
idk if this is a bug or not:
my battery sometimes will not charge... when i plug it in it shows the little lightning bolt but it doesn't show the "filling up" animation... i have to power cycle it sometimes up to 3 times before it will actually charge...
does anyone else have this problem??? or is it a faulty phone?
im hoping its the latter... then maybe i can get a new one and go back to root![]()
What a mess of a statement.
- Who are "they?" HTC techs, developers? Verizon sales, techs? Do you feel that all of those entities have arranged a conspiracy, beginning back before the Eris was released, to sell Incredibles?
- How is "pushing" a new phone going to cease ongoing development of updates for a slightly earlier device?
- Three leaks of the 2.1 update for the Eris have now been exposed, lending more than just passing credence to the notion that an OTA is chomping at the bit and eager to find its way to our phones (those of us with 1.5, for certain, and maybe those with one of the leaks installed).
i couldn't be sure if it had ever happened in 1.5.... i almost immediately flashed to 2.1...I've had this happen once or twice and like you I'm not sure if it has something to do with the leak or if it's hardware related. I also can't remember if it happened in 1.5.
I as well updated to 2.1v3 and over all im pretty pleased. a few things I dont like/bugs..
Incoming calls -sometimes when recieving a call, my ohine screen turns black for about 10 sec. , and then will flash the caller ID... :-(
my signal is around 2 bars all day. only seen a full signal once or twice
battery life still sucks (no pun intended)
Handcentsms is laggy
phone dialer is VERY laggy..
other than that , its WAY better than the 1.5....ANY suggestions on how to fix these problems??![]()
het everyone, just thought i would throw this out there, i upgraded to the 2.1v3 leak and it has been ok. I am having new problems i wasnt before, while having 1 problem that continued after upgrading. New problems are, the silent phone thing. I am having to reset my phone atleast 3 times a day due to this problem, try to make a phone call, dials....no sound at all, try to press on keypad, no sound.
