Hi there,
I did some searching and can't find this problem. If there is an answer out there, please point me to it or help me figure out what's going on.
My eris is on 1.5 (I don't want to go through the manual install of a leak and would rather just wait....)
I am trying to unlock my phone so I can turn off the stream I am listening to in the app StreamFurious Pro but I can not. When I tap the red button right of the track ball, the lock screen comes up, but then when I swipe down it only slides part of the way and then starts to shimmy or bounce up and down. I can see the browser window I last had open below it, but I cant get to anything because the lock won't slide all the way down. Even when that grey bar does get all the way gone, it bounces back a second later.
The menu button does not respond.
If I hit the red button again to send it to sleep, it does. Letting it sit does not help. When I hit the red button again, it either shows the grey bar you grab still bouncing, or the lock screen again, but the same thing then happens.
I have had streamFurious Pro for awhile and never had this issue. I have not added any new apps since yesterday AM and used my phone just fine between then and now.
Thanks for your help
