Root Eris Root Explots/Methods Tried.....For anyone to poke through...
acidbath5546
I took a Hiatus/Leave from the now Semi-Defunked Eris Root Dev Team.
XDA became a flamer zone, and I decided to move on to bigger and better things
Just in case anyone out there is looking to work more on Root/Exploits, here is a bunch of tried and failed info/links
A lot of people are New and want to learn, This is AWESOME!
So if you are new and want learn a bit more and maybe Root or Cook you own ROM down the road here is some ideas :)
What really helped me was downloading an ubuntu enviornment and messing around with that.
Head over to XDA and check out the old G1 and Hero ROM/Root Threads.
This site was great for me starting:
KernelHacking - Linux Kernel Newbies
I would say start here:
CompleteNewbiesClickHere - Linux Kernel Newbies
Known Exploits for our Eris!
Exploits for Eris
Feel free to edit and publish more you've found!
http://downloads.securityfocus.com/v...oits/36901-2.c - Nindoja simpler exploit
Linux Kernel 'pipe.c' Local Privilege Escalation Vulnerability
http://downloads.securityfocus.com/v...oits/36901-1.c
http://xorl.wordpress.com/2010/01/14...se-after-free/ - FASYNC; Will work after removing at_random (At_random doesn't exist on Eris)
Rooting Status/Methods:
HTC Released out Kernel Code for our Eris! see here:
HTC - Developer Center
We should use this Format (thanks Videofolife13)
Tried: milw0rm/exploits/8478
Worked (y/n): no
Why?: Does not effect this Kernel Version.
Tried: asroot2
Worked (y/n): no
Why?: Hole was more than likely patched.
Tried: Flashrec
Worked (y/n): No
Why?: See above
Tried: Renaming a rom UPDATE.ZIP / PB001ZIP
Worked (y/n): no
Why?: Roms are signed by HTC. We can't sign our own
Tried: Linux Kernel 2.6 UDEV Local Privilege Escalation Exploit
Worked (y/n): no
Why?: I don't know. May be something to look further into.
Tried: current->clear_child_tid pointer http://web.nvd.nist.gov/view/vuln/de...=CVE-2009-2848
Worked (y/n): ?
Why?: Never followed up
Tried: Buffer over run open ports
Worked (y/n): ?
Why?: Suggested by Jmanly, but documentation for an exploit that could work was never found.
Tried: Editing recovery.zip that goes right into the Ruu
Worked (y/n): no
Why?: This was trying to use the RUU to our advantage and write a custom recovery image to the phone through it. It didn't work because the modified roms failed a signature check.
Tried: Buffers/Editing Recovery/Running Different Recoveries.
Worked (y/n): no
Why?: just didnt want too..would not patch/run successfully
Tried:
Linux Kernel 'drivers/scsi/gdth.c' Local Privilege Escalation Vulnerability Here is some more info on it. Problem Description: Some vulnerabilities were discovered and corrected in the Linux 2.6 kernel: Array index error in the gdth_read_event function in drivers/scsi/gdth.c in the Linux kernel before 2.6.32-rc8 allows local users to cause a denial of service or possibly gain privileges via a negative event index in an IOCTL request. (CVE-2009-3080).
Result:
SCSI support hasn't been compiled in for our device
Tried:
Result:
This exploit is better known in the Android community as "asroot2".
Vulnerable Devices:
Hero
Patched Devices:
Droid Eris (Desire)
Tried:
Linux Kernel 2.4 and 2.6 Local Information Disclosure Vulnerability
Result:
Just a local information disclosure bug; definitely the cocoon of a vulnerability, but not a vulnerability in itself.
Tried:
Linux Kernel 'fasync_helper()' Local Privilege Escalation Vulnerability
Result:
Turns out our device was not vulnerable.
Tried:
Linux Kernel 'ebtables' Security Bypass Vulnerability
Result:
Just a vulnerability against etables, a firewall and internet traffic filtering software.
Tried:
Replacing the stock imgs in the google SDK with that we have gotten from the eris to adb pull files.
Result:
All of what the RUU does can be found in the same place as "rom.zip" after it has been loaded. XDA has a tutorial, I don't remember where just somewhere in %APPDATA%/Temp. The "fastboot oem" commands only work in oem-78 mode (or w/e it is). We still can't push unsigned zip's here though, tried and failed.
Name: udev priveledge escalation
Known Exploits:
Linux Kernel 2.6 UDEV < 141 Local Privilege Escalation Exploit
Tried: #8572: Compiles but doesnt do anything. Turns out android doesnt use udev apparently, so this won't work.
Name: pipe.c bug (aka asroot2)
Known Exploits:
Linux Kernel 'pipe.c' Local Privilege Escalation Vulnerability (there are 4 different implementations here)
Tried: Already been tried before as mentioned on the xda forums, turns out Eris kernel has a patch
Name: sock_sendpage() / ip_append_data()
Known Exploits: there are a tonne of Implementations for this one on milw0rm, the two that may apply to eris I believe are:
Linux Kernel 2.4/2.6 sock_sendpage() ring0 Root Exploit (simple ver)
Linux Kernel 2.4/2.6 sock_sendpage() Local Root Exploit (ppc) (this one might only apply to SElinux)
Tried: I am trying to get 9479 to compile still, and some of the implementations mention use of pulseaudio, which I am not sure is available on Eris
Tried: reflash using mtty
Failed : only works for Windows Mobile
But hey, thanks for all the info and websited Acid!! You are a gentleman and a scholar. (ps let me know whats up with the nexus one ROM, I'm gettin it when big red lets it out of the bag too :-P) :D
No worries... we have devs still working on getting this thing rooted and not ones who give up... :p ... We will update androidforums and xda as soon as we get updates...
