Eris Volume Button
cmlamorte
Hi, I was wondering if there is anywhere I can find a replacement volume button for the droid eris, or where I can get mine repaired. I am about to buy an eris off of craigslist and need the only thing wrong with it is that it needs a new volume button. Anyone out there that can help? Thanks!
I think the volume rocker is attached to the battery cover. You'll probably have to do a search on ebay or amazon for a replacement.
If its just the volume rocker and not the actual switch, it should be rather easy and inexpensive to fix (new battery cover). I'm sure they have replacements somewhere.
