Wirewrapper1
Hello, Just got a Galaxy S2 4g the other day and so far I love the device except for one problem, calls seem to do fine as well as texts, But 3g seems to cut in and out a lot. Sometimes i will go into many my apps and it wont connect and ill get a log in error, webpages wont load etc. Could this be caused from upgrading it to jellybean (via the tools from samsung) or something else ? I can get it to connect up (temporarily) by either rebooting the phone or entering/exiting airplane mode but it can be a hassle if i just want to quickly look things up.
Any help would be appreciated !
And here is the info from the phone if it helps:
Model number : SPH-D710VMUB
Android Version: 4.1.2
Baseband Version: S
710.10 S.GB28
Kernel Version: 3.0.31-1014481
se.infra@SEP-102 #3
SMP PREEMPT Fri Mar 1 4:29:59
KST 2013
Build Number JZ054K.SPH-D710.GB28
Hardware Version: D710.10
Software Version: GB28
And on an another note just in case its something geographical with the S2 Im in the Shenandoah Valley of Virginia. My old phone never had a connection problem here and i would think the S2 would have a better connection being a newer phone and all but that doesn't seem to be the case so its worth putting in the question, lol
Baseband Version: S
710.10 S.GB28Kernel Version: 3.0.31-1014481
se.infra@SEP-102 #3
KST 2013
