Friends
I own a HTC Desire HD with the current specs:
ACE PVT SHIP S-ON RL
HBOOT-2.00.0027
MICROP-0483
RADIO-26.14.04.28_M
eMMC-BOOT
Sep 7 2011, 19:06:24
I have been trying to unlock it now for a while and have been un-successful.
It seems the problem is I cannot update the hboot from the ...27 version to a newer one.
Here is what I have done and which does not work:
- I go to the HTCDEV site
- Then I start the process to Unlock the Bootloader
- I find that the page then tells me that my model needs an hboot update.
- Next I go down the list of carriers and ROM's and find the one I assume is the one I need, the hTC Asia WWE 3.13.707.4 PD9810000.
That is, I d/l the file PD9810000_Ace_Sense30_S_hboot_2.00.0029.exe.
My ROM is 3.13.707.3 and phone bought in China.
-Next I follow the instructions as described on the HTCDEV site.
- I run the .exe file above, in Admin mode on my Vista Pro 64 bit system.
- It starts up fine and runs all the way till it encounters an error that says "Error [190] ROM not updated"
then
"Your ROM version is not the latest version. Please upgrade to 3.13.707.3 to appy this RUU to be able to unlock your bootloader."
BUT, that is already the version I have installed!
I noticed that the program to update the hboot actually says that I have the version 3.13.707.3 installed and then it ask me if I want to install version 3.13.0.0! If I say OK then it gives me the error message above about the need to upgrade to version ...707.3. So it looks like it wants me to downgrade first to version 3.13.0.0 and then it gets confused.
If I got it correctly then I need the hboot version 2.00.0029 in order to be able to unlock my HD. But how can I go about doing it successfully?
Is there another RUU that I should download then?
Any good comments are welcome.
Thanks,
Calle2012
HBOOT-2.00.0027
MICROP-0483
RADIO-26.14.04.28_M
eMMC-BOOT
then
Thanks,
Calle2012
you could easily do that first,if you prefer to.
