Error after factory reset -sim not provisioned MM#2
micherri
I purchased a second hand Galaxy s2 I was told it had been unlocked ( originally it was locked to At&T) Current Sim card is prepaid with straight talk and is about 3 months old. I did a factory reset on the phone and now I get this message sim not provisioned MM#2. Does this mean the SIM is deactivated only or is it because I have wiped the unlock code?
Thank you
Factory reset shouldn't do either one. Call Straight Talk (that's lots of fun) and ask them to reprovision your caaount. At worst they'll have to send you a new SIM.
DO NOT mention anything about the phone being unlocked. (If it was an AT&T phone and you're using a ST AT&T SIM, or it was a T-Mobile phone and you're using a T-Mobile SIM, it doesn't even have to be unlocked . It's locked to the carrier, and that wouldn't change.)
