Root <ERROR> Application villainrom updater is not responding???
islandmixed
After trying out another rom which is villainrom..iam getting this damn error each time my phone loads up, then it gives me a option to wait or close. This is why i always seem to regret trying out any villain roms..always some errors that creep up & folks say they are stable. is their a way to correct this? maybe i should try sence build 5..cause sence 2.2 was good but i wanted to try the new villain.
cheers if anybody can help me.
Somebody posted a fix for this in another thread. Step 1 was to turn off automatic checks for updates in the villain updater.
Bear with me whilst I find it again.
EDIT: Here
Unmount your sd card or unplug it from your computer. If the sd card is mounted on the computer updater will not work and will produce this error.
