Root Error on attempt to put rom in
Hey, I'm helping my friend install a new rom on his Droid X because the GB update messed his phone up. The Recovery version is 2.xxxx. I have Team Liquid's rom which won't install and it says
"E: failed to verify whole-file signature"
"E: signature verification failed"
"Installation aborted."
CAN SOMEONE GIVE ME A SOLUTION
You are bootlooping. You will need to wipe all you data by going into stock recovery. Do this by holding the home button and power at the same time. When you see the android triangle let the buttons go and press both volume up and down at the same time. You need to navigate down using the volume down button to wipe data/factory reset. Press the power button to select. Once this is finished you should be able to boot up. If not you will need to Sbf the phone. Check the guides for all the instructions on how to do this. Good luck and be sure to come back if you need more help. Once you fix this problem you can check out the guide for flashing Roms.
More than likely ur going to have to SBf it to the .602 then root it again then make sure u wipe data and catcha* (sorry for the spelling) then try and load up liquid gingerbread 3.1 all the things u need r on the sticky's at the top of the root section that should help
@mat I think I have tried this but I will do it again and if I and .602 does it matter if i root it with 4root and one click root and stuff like that does that effect it
if you are getting a signature problem then someething was done to the rom prior to installing, and its failing because of that, android will not install anything that isnt signed.
redownload the rom, or try a different one, and it will install, just make sure you wipe data and cache first
Non of the 1-click on phone wont work on any of the gb read the sticky's up top of the rooted section
the rom and theme list has all the roms for the DX and themes available for it. its in the sticky at the top of the page.
