Root Error: Unfortunately, System UI has stopped
Gee92
I have this appearing on my galaxy s4 after rooting (via CF-auto-root) (worked fine) and then in CWM ROM manager i tried flashing CWM superuser and then i wiped cache and rebooted to find this error message a black wallpaper/background instead of the original blue and the drop down tab (pull down from the top of the screen) in-accessable also the home button no longer works??? Appart from that the rest of the phone works fine to the best of my knowledge. Anyone any ideas
Hello there!
I've moved your post into its own thread in your device's root forum for you:)
Others who are rooted and with your device can help.
Since moving, you may want to clarify what error you are getting...I left the thread title the same (from the original thread it was in) assuming that was the error you are getting;)
Good luck!
