cyn
Member
I guess I'm one of the few that had glitches w/ the update. First the galery link on the front page didn't update and I kept getting "this application is not installed" error. I couldn't drag it over to the red waste basket...it kept changing back to gray and the faulty icon stayed on the main desktop. That evening while on hold to Verizon I "force fed" it by holding it over the waste basket longer, then added the new gallery app from the slider screen.
Also noted that the gold button on the r side no longer worked for the camera, it brings up a quick messaging screen instead. They determined the ONLY way to fix this is to reset the phone back to factory issue. Is there another way around this? Or if I have to, what's the best way to back up everything and keep track of the installed apps? I really don't want to reset the phone. Thanks, Cyn
