Machu
I installed 'ES File Explorer' app in my newly bought Lenovo K3 Note. Soon after I noticed that I can't delete or rename any file in the external card using the app. Its working fine when editing any file in the internal memory. The inbuilt File Browser lets me edit all files irrespective of whether its in Sdcard0 or sdcard1.
When I try to edit any file in the sdcard1, it shows an image which says "Please choose the root directory STRONTIUM(/storage/sdcard1) of ext-SDCard to grant ES permission to operate." and also shows step by step instructions for how to do it. Which is "Open from - > recent - > ... - > show SD card-> SD Card-> select 'SD Card'". But when I try following the steps I can't find' show SD Card' in the options. It only shows "Hide file size".
Can anyone tell me what could be the problem? Should I root my phone.
I also discovered the same problem while trying to edit tags of songs stored in sdcard1 using PlayerPro app.
