Help ES File Explorer Question
Hello. When I am using ES File Explorer, and open up a picture within several sub folders on the network or sd card, there is no option that I can see to go back to that same folder. In other words, I am unable to exit the picture and enter directly into the folder that picture was located in. Pressing the return button next to the home and button takes me back to the start of the sd card folder. Any idea what to do?
I'm not clear what your issue is. I can navigate to any folder (on-device or network), drill further down to sub-folders, view a file/picture and then simply press the "return" button (next to the home button) to get one level back to where I was before. I can also achieve the same effect using the level-up button within EStrongs. ;)
