Root Esteemed them
androiduser96
I updated to Gingersteem Extreme recently, but unfortunately I don't really like the Gingerfusion theme so much. I'm looking for the Esteemed theme. Does anyone have it? or can help me get it?
Shinyside (Thank you) tried helping by giving it to me but the notification bar and settings look didn't change.
I'm on the same boat, not too fond of the notification buttons but I do like the status bar. I'm just gonna bear with it for a while, won't be too long before someone figures out how to change it. Also I think ROM Toolbox PRO let's you change the icons on the status bar but I'm not sure if it would cause problems. I read somewhere that some features of RTB require that T-Mobile Theme Manager thing which isn't compatible with this phone. :/
It works great for changing the icons. I have had no problems and for that part you don't need T-Mobile Theme Manager.
I didn't like the theme then flashed again Gingersteem (not the extreme) and flashed PG 2.0 GHz OC'd Kernell on top of it. Problem resolved.
just flash this rom over the one you currently have, then update the kernal as dany has said.
http://androidforums.com/esteem-all...-gingersteem-rom-1-0-w-blitzkrieg-kernel.html
