You are correct. I seriously jumped the gun and made some mistakes in my post. The TB does indeed use both the Snapdragon SoC and MDM9600 chipset (MDM is not a single chip just to be clear - it is 6 chips - hence "chipset"). However, the MDM9600 is much like the Snapdragon in that it is a evolutionary step in a long line of similar products and absolutely is not at all a "first of its kind" nor "first generation". In that the OP is still incorrect.
I still also contend that any link between problems with a modem product using the same chipset and the TB is HIGHLY speculative at best.
Anyway, sorry to the OP and to all.
What other chip supports LTE all CDMA and GSM technologies combined and it's backwards compatable with all the legacy 2G and 2.5G? Thats why it's first of it's kind. I don't mind engaging in constructive debate, but you're mixing CPU with rf chip...
I know you didn't have bad intention so it's all good.
The only addition to the chip set is LTE and that is not even at new frequencies. Hence I call it an evolutionary chip set not revolutionary and is definitely not a "first generation" chip set. It builds on the backs of all of the prior and very similar MDM chip sets.
It's not the only addition. It's the first chip with LTE capability that's fully backwards compatible with legacy GSM/CDMA modes.The only addition to the chip set is LTE and that is not even at new frequencies. Hence I call it an evolutionary chip set not revolutionary and is definitely not a "first generation" chip set. It builds on the backs of all of the prior and very similar MDM chip sets.
Anyway, it's useless to waste time on this matter, let's stay on subject.
The MSM8655 has the MDM9600 integrated into it.
Just wrong.
