Root Evernote / cm7 problem
thangfish
Android Expert
Has anyone been having database read/write errors with Evernote and cm7 lately?
It happens whole it says "upgrading database" and I get window with an sqlite exception.
Annoyingly keeps me from using Evernote.
The only seeming common denominator on their forum is cm7.
I'm running g60 07 and whatever the current update from Evernote is. can't get in to look.
I know this is going to sound like a dumb response, but try uninstalling and reinstalling. Then, leave a comment in the Play Store under Evernote or email their developer. Since we don't have the code, we cannot fix it here. Opera Mobile had issues with CM7, and they fixed the issues after I filed a bug report with them and left comments in the Play Store.
Thanks for the response.
I didn't ask for you to fix it, or for advise on submitting a report : confused:
I asked if anyone else is having this particular issue. Trying to figure out how widespread it may or may not be.
If you feel like replying to my question, feel free.
Sorry. But I do not use Evernote. I know you're intelligent enough to solve the problem, it's just that sometimes we may forget the obvious. Happens to me all the time. However, I can try installing Evernote and see if I have the same problem.
Nah, don't bother.
As popular as it is, I'm sure some peeps around here are using it already... maybe they'll chime in.
Seems to be device independent, with cm7 being a possible link.
Running Evernote on g60 0.6. They seem to be working smoothly together with no problems so far for me.
I used to get this error all the time. What fixed it for me was removing the app(completely - deleting the evernote folder on the sd card) then reinstalling the app and signing in right away after installing it. When I got the error, I had installed the app but didn't sign in right away and it would give me that error every 15 - 30 min!
That's the symptoms alright.
I reverted to the previous version and it's fine.
when I remember my password I'll probably do what you did... that's the only reason I haven't done it yet :D
