Root Everythings a mess,phone wont work.
TheRisky
Yesterday i tried installing 4.0 Ice Cream Sandwich.
I followed the instructions as written,when booting the device however, it would not start.The LG screen came up, after that the shards came flying and then the screen froze.I tried waiting for god knows how long, but it doesnt work.
So with my "Smart" brain i tried fixing things on my own, but the phone was so messed up at the time, it didnt even connect properly with the USB.
So.When i first installed 2.3 on my phone, i left all the installers and files that came with an installer pack.One of them was a file called "B2CAppSetup".
I assumed its a LG update program or something.To my Luck it was.It connected with the phone as it should have and started installing an update.After it completed, it showed the LG logo again, and then after that another LG logo, but with Blue lights surrounding it (Like the original boot screen for 2.1 if im correct), but then after that, nothing.So what do i do now?
On the LG Support Tool (the program that updated the phone) there is a tab named "Customer Support", theres a tab called "Recovery Phone", should i use it?
Help!!
Help!!
Probably forgot to wipe data, boot to recovery and select wipe data/factory reset, however running that setup app might have messed things up if its changed the bootanimation.
