Help EVO 4g doesn read 32 GB SD. Help!
I changed my 8gb card for a 32gb class 4 sdhc card and my phone is constantly failing to read what's on the card. The pictures appear as STATIC and the apps that I move to the card do not appear on my phone. Is there some sort of specific cards that I should be using, or not using???:confused:
FYI- ALL Phone updates have been performed.
There are known issues with the EVO and 32 gb cards.
You can try reformatting it
So far, this seems to have helped. Originally, I just copied everything from my 8gb original one, which was a different brand. Perhaps, that contributed to the issue. Like I said, so far so good...
Thanks!
