Help Evo 4g Fonts
PuR3 G3o
Is there anyway to change from my rooted font back to the factory font i recently downloaded rom manager and changed the font but it never saved my factory font what can i do to get it back??
You are rooted correct?
If you're rooted you can flash the Rom you are currently on over your current setup. Make sure the Rom you flash is exactly the same as what you have installed, same version # etc.
Just wipe the cache partition and the dalvik cache, then flash the Rom again. This will bring the Rom to It's "stock" form, without deleting your data. :)
That will get your original fonts back.
okay thanks for that but i know this is going to seem really stupid but how do i exactly flash my rom
The only stupid question is the one that was never asked. ;) Don't worry about asking questions here, you'll have folks crawling over each other to help you. :D
Do you have the original file you flashed for your current Rom?
If you didn't flash a Rom, you're still on the latest update stock rooted Rom. I'm on my phone at the moment, or I would link you the stock rooted Rom.
Let me know what Rom you're on and we'll get you fixed up. :)
Hey i tried to flash my fone and it did not reset anything it made all my contacts erase from my sd card erased my apps and pictures.(but thats not a problem) the problem is now it wont load the recovery menu Pleasee Help at this point im just dying to reset it back to factory yet it wont let me Please HELP
