Help Evo 4g help.
Today I wrote a very long text message it was about 7 messages long after about five messages it said converting to mms message. i finished the message and i accidentally pressed back and it said saved to drafts. so i went to drafts and i cant find it. this message is the most important text message ive ever sent and probably ever will sendis there anyway that i can get it back?
It should be saved under your messaging app. Select the contact you were sending that to and it should be there.
well.. are you using a custom ROM? was it the stock message app or some sms app you downloaded?
edit.. on my evo 4G.. with sense.
i just tested it... typed a mesage.. and backed out.
the message was saved .. in the same area that you where in.. under the contact you were sending to.
if it aint there.. i don know what to say.. maybe the size of your text cause an issue. sorry
