Has this happened suddenly? i.e...it worked fine before and then for no reason, stopped working?
Have you changed roms? Have you messed with the APN settings at all?
Can you browse the internet fine?
Sorry for all the questions but just needed to narrow things down a little
For a hopefully simple fix, boot into recovery, clear cache and dalvik cache, reboot and try it again
Is it the stock messaging app?
No it is not the stock mms as the phone is flash to metropcs cashe/dav didn't help.
Just for giggles, try the messaging app that came with the rom.
Did I understand correctly, you are not using the stock messaging app?
Maybe I don't understand the rom you are on and the messaging app.?
I guess what I'm getting at is, try a different app to send mms. Such as GoSmsPro or Chomp to see if those work.
ok in the last 24 hours i have tried 4 diff roms even one strickly for metro
and the same thing txt are ok i can receive pix but to the life of me i can't send
so it is not in the roms but be something on the phone i check the flash to metropcs setting 3 times nothing seems wrong this is getting me LOCO
did you flash the mms script in the thread i linked to earlier?
This is all the useful info i have as of right now for anyone with an HTC Evo flashed to metro pcs.I am willing to add or edit any info i have provided to make things EASIER to find for this specific phone one METRO PCS.Thanks for your suggestions in advance and i hope this info with help!
To program data to Metro pcs (must be using a SENSE rom) clickhere
For ROMS click here (rom's are out-of-box metro-ready:CM7 & Sense 2.0)
For all the zip's your gonna need,download from these 2 links metrOFF & MetroPCS MMS & Web Script
The .zip titled"MetroPCS Evo AOSP MMS & Web Script v4" you can use to fix MMS on ANY AOSP and most MIUI ROM's.Just flash it AFTER you flash the ROM of your choice and it should fix your MMS.(MAY NEED TO REBOOT TWICE)There is ALSO a similar WEB/MMS fix for SENSE ROM's as well in the same link above.
no i the thread i link there is a script that you flash in recovery.
this is from the guide:
in the MetroPCS Evo AOSP MMS & Web Script v4 link there is a script for sense that you want to flash. you want the first one titled:MetroPCS Sense 2.1/3.0 Hybrids MMS & Web Script v5 (if your are on mikg3.11)
this is not a rom, but a script to help with mms on metro. you just flash it in recovery. make sure to wipe dalvik cache and cache before flashing it.
well then you got me....i'm not sure what else you can do. did you flash the phone yourself?
well then you know more then me about flashing to other networks like that. but if the mms script did not work then i'm all fresh out of ideas.
