Help EVO Extended battery widget
flmarcus
Anyone know of a good widget for an extended battery for the EVO ?? I was told by Sprint that the one I was using was not for the evo 2600mAh battery. I have been getting great results but every few days, well once a week or so the battery dies without warning or doing anything different.
Thanks
Thanks
What? A widget isn't gonna stop your phone from dying. Sounds like you have a bad battery or it needs calibration.
I'm confused. Are you saying the Sprint rep told you the widget was not meant for the EVO or the battery was not meant for the EVO?
If it's an Android widget, it should work (unless it totally sucks). What battery widget are you using?
Sprint Rep on the phone told me some months ago that there is not yet a "Widget" for the extended battery. My phone was messing up alot and he told me to remove the battery widget. I was wondering if there is any out there yet for the "Extended Battery"
Hey.. I bought the extended battery 2600mah from Sprint as well and mine is working great!! Try juice defender with ultimate juice that works great for me!!! Battery last way longer!! And ps you have the correct battery!!! That 3500 mah battery is a 3rd party battery which may cause leaking overheating and then the evo will be ****ed cause it wasn't from Sprint or HTC therefore those guys will be ****ed !!!! That's why I also bought the 2600mah battery from sprint instead !!!
