Hey guys. I've got an EVO that I have had for about a month now, and have had little to no problems at all. Yes, it has lagged a few times, but it would always force close whatever was causing the problem and restart it right away, so I had no complaints.
Unfortunately, now it has frozen entirely. I am stuck on the screen with the generic unlock slider, which looks completely normal, but will not respond to touch. The slider does not move at all when I try to touch it. Sometimes, the screen will jump to the 'draw unlock pattern' screen as if the phone was simply lagging, but that screen will immediately say to try again even though I have entered no code. I have the pattern screen set up to vibrate when a node is crossed, but there is no vibrating except for randomly when I have stopped trying to draw the pattern sometimes.
I have received multiple calls while the phone is in this frozen state, and the phone will ring correctly with my custom ring tones for specific people, but will play said custom ring tone well after they have stopped calling, and remains frozen on the slider screen (I cannot answer the call).
At one point, the whole screen became blurred, like the screen was covered with fog, but cleared up after several minutes.
I have a gmail notification, a text notification, and a missed call notification on the notifier bar at the top of the slider screen, and the USB charging and debugging icons (triangle with !, right?) show up when I plug the phone in and do disappear after I unplug, though the change is laggy - does not register until after I hit the power button once to blacken screen and a few seconds after I hit the power button again to bring the slider screen back.
I have already taken the battery out three times, waiting for a couple minutes each time before I replaced the battery and powered the phone back on, only to find the same problem: I am stuck on the slider screen, with periodic access to the pattern page, both of which are unresponsive.
Any ideas on what can be done? I have not modified the phone in any way outside of downloading a couple of apps, like the battery widget. Do I need to use something on a computer to access the phone while it is USB connected?
Thanks so much for your help, and sorry for the trouble. Please ask if any further detail is necessary.
