Help EVO Issues???
Mine is watching me when I sleep, with the kickstand open and the desk clock on. So when I wake up every hour to make sure its still there It will tell me the time. This phone is sweet. I think the world is changing already.
I've had sense restart on me a couple of times, but I'm pretty sure it's related to the SD card. I know the update is out but it breaks root.
It's bern running pretty well for me. Only thing that could better is the battery but that will require conditioning and tweaking the settings.
Sent via EVO 4G
Battery sucked the first day. Always recharging when I could. Got task kiler and put a good long charge on it and battery had 1/4 left after a normal full days use. That's with a litte 4g, alot of internet, sprint tv, etc. If I can keep it in this range I can be happy with it. Ordered 2 more batteries last night just for emergencies
One persons battery exploded I'm having trouble out of mine etc etc there have been a couple issues but so far none widespread.
Well I think one main issue would have to be that at the end of the day my eyes are watering from staring at the screen too much!
Although... I have had one thing thay bothers me... I use the desk clock at night and after my alarm goes off my lock screen will not come back on.. I have tried everything and so far restarting is working. Is anyone else having this issue?
well i seem to be having a problem that i cant set individual ringtones for individual people. only the default continues to ring
i downloaded ringo pro and the same thing so i dont know should i just reformat the phone and try again and if i do that how can i get my phone numbers back im really new to droid so this might be something really simple to someone more experienced
Mine reboots every half hour. No task killer installed and no strange apps. Not sure what the hell is going on here.
My You Tube App Crashes sometimes. Not sure what causes it. but once it crashes it won't load until I reboot phone. Only issue so far.
had the light leakage, raised screen, and grounding issue on the first
I now have the light leakage, screen is raised more than the first, and grounding issue
