EVO on GSM/WCDMA networks????
FLEMTP
Member
Ok earlier when I was browsing around I found a thread that talks about putting in different codes into the keypad to get your phone to do different things. So I tried one of them...
*#*#4636#*#*
When i put this code into my phone it brings up a menu called "testing" in the top bar.. then it has 4 menu's
Phone Information
Battery information
Battery History
Usage Statistics
When I select Phone information among the various menu options and infomation given there is a dropdown menu under
"set preferred network type"
when you select it, there are several options:
WCDMA preferred
GSM only
WCDMA only
GSM auto (PRL)
CDMA auto (PRL)
CDMA only
EvDo only
GSM/CDMA auto (PRL)
Unknown
So.. does this mean you can use this phone on a GSM or a WCDMA network???
Anyone who might know I would GREATLY appreciate some insight!!!
