Everytime i try to enter recovery mode it goes into the startup image , the white screen with the words "htc evo 4g" and thats it , it never changes. I looked everywhere on what to do.
Its says to : flash clockmod recovery and then try. : failed , Download QuickBoot and use that app to enter recovery : Failed , then it says hold the volume down and power and enter recovery the old fashioned way: failed it all does the same thing. Its almost like the phone is searching for a recovery file thats not there so it freezes or something. so i need some help on what to do and what files to download and put where , as long as i can enter recovery one time i will be sooo greatful. Please help thanks
J+9
Its says to : flash clockmod recovery and then try. : failed , Download QuickBoot and use that app to enter recovery : Failed , then it says hold the volume down and power and enter recovery the old fashioned way: failed it all does the same thing. Its almost like the phone is searching for a recovery file thats not there so it freezes or something. so i need some help on what to do and what files to download and put where , as long as i can enter recovery one time i will be sooo greatful. Please help thanks J+9
i used unrevoked but it was wierd because it said it failed but i still got superuser permissions and the wireless tether worked. 3. I have been able to enter recovery one time and i tried to install Cyanogen Rom , but it failed because it was stuck in a boot loop - so i took out the battery and idk how i fixed that. 4. I tried to flash clockwork using RomManager, it says it works then when i go to "reboot into recovery" it just goes into the white "htc evo 4g" screen. thanks so much - and sorry i am such a noob
