crump
UPDATE: You can now downgrade your hboot and use the old froyo root method.
Hboot information and downgrading - xda-developers
The steps include
1. Temp root using Fr3vo
2. Exploit the hboot with the misc.img
3. RUU back to froyo
4. Root using the Froyo method
EDIT: This method is primarily for 2.3.3.. If you are running 2.3.4 check this thread Root and downgrade for Android 2.3.4 {Script included - ShiftySonofA script dl added) - xda-developers
Also here's a "how to" for rooting.. [VIDEO GUIDE] FULL S-OFF ROOT for Evo SHIFT. Froyo (2.2) + Gingerbread (2.3.3+2.3.4) - xda-developers *The method mentioned for 2.3.4 will void your warranty* I would suggest the above script..
Good luck
The steps include
Good luck
