Help Evo Text bugs?
Evo 5oh
So you know how every time you get a text theres a number on green on the evo? Well every time i get a text from somebody it shows the wrong number for example .. I get a reply and instead of saying (1) it says (4) ..
also sometimes when i answer back to a text it says i got a new text from the person but when i look is actually my reply ....
im talking to sprint about while writing this thread and they said..
Dallas Y.: Yes, that is right. There are some certain known issues are going on with the EVO after updated the software with the gingerbread and we have already escalated the issues to our Technical Support Team and they are working on it to get it resolved as soon as they can.
Dallas Y.: There are also some known issues are going on with the voicemail notifications as well like you are getting with the text.
3:18:06 PM :​
Dallas Y.: We educate the customer to erase the notification and appreciate their patience during the time our Technical Support Team is searching for the resolution.
You will be receiving such updates notification on your phone sooner by doing which the problem you are having with the text notification will be also fixed.
3:22:31 PM :​
Dallas Y.: Yes, we are diligently working on it and appreciate your patience while we are working hard to get your issue resolved since it is a software issue which needs to get research by the specialists to do the correct troubleshooting and the updates requires to resolve the problem our customers are having with the notification related issues.
