Help EVO - trouble with Exchange not syncing
SS55
Hello I just purchased the EVO and i am trying to connect to my work email and it is not doing it. We use the Exchange format and when i put in my information it says password/username invalid etc. I had the instict previously and I never had any issues. Does anyone else have problems connecting with the EVO to exchange? If so is there anything I can do?
You should talk to your IT department. It could be a simply be a configuration problem on their side, possibly a firewall that may not be allowing you through, or maybe something that needs to be activated on your Exchange account. It could also be something you are doing wrong. Your IT department would know better than anyone here.
If it was working for the Instinct, you would think it would work on the Evo however. IT can look at the logs and point you in the right direction.
