Found the phone numbers for executive support. I'll be calling tomorrow.
Virgin Mobile - Executive Resolution Team
We'll start out slow...
855-250-5271
877-600-8065
CSR Retention Department(s) 24/7 - 365
Now, those are easily found around the web and since they've been heavily abused are finicky - at best. Sometimes they'll be disconnected, other times they'll re-route you to the regular, incompetent, script addled CSRs that can do nothing but throw 40min kick backs at you. Every now and then those two numbers can produce results but it'll be luck that you might get the retention department.
Alright so let's move up a level...
877-291-5717
Executive Resolution/Escalation Team Call Center -- Mon - Fri: 7am - 4pm CST
This is the actual Executive Resolution Team Call Centers number. The phone will be immediately answered and the operator will ask which representative they can transfer you to. Don't panic that you don't have one just explain this number has been given to you by another CSR to speak with a Executive Resolution/Escalation Member - they'll take your info and transfer you to a ERT.
NOTE: I can say don't abuse the previous number or the next two I'm about to give you but I know it won't do any good. But know this; if the previous or next two numbers are your FIRST call, first e-mail, tweet, facebook post - whatever - line of communication company they will dump you back into the regular CSR pool. You don't need to cause a scene carpet bombing their CS departments before hand but it'd be best for your account to be annotated before using these first.
Alright let's move on...
817-698-2096
Advanced Executive Resolution Technician -- Preston: Mon - Fri: 7am - 4pmCST
This is a direct line to Preston. These are the techs to the Executive Resolution Team, these folks don't read from scripts. They write the scripts. This one's tricky because this tech is routed from ERTs they don't make change to your account on anything but a technical level.
And finally. Saved the best one for last so if you've read this far, here you go.
817-215-3658
Marco.A.Medina@sprint.com
Executive Resolution Team Manager: Mon - Fri: 9am - 5pm CST
This rep can do ANYTHING to your account, he handles the highest level complaints that fall under the Sprint umbrella. My problem was monetary and technical, to put it simply my account from top to bottom was a complete clusterf*ck that no one after dozens upon dozen of correspondence(phone, letter, e-mail, facebook and twitter). After finally carpet bombing any and all Virgin(whether mobile, in the UK, media or travel) executives I got a call and e-mail from Marco. 24hrs later everything was fixed. He had to look into it, he had to review my account but he wasn't staling - he was simply making sure everything was right. It was.
There you go, hope they help and if you abuse these numbers for BS reasons I hope your phone explodes in your face.
