Blue_Turtle
Member
Anyone know when the HTC case w/kickstand will be out?
Its already out and i have it. It is quite nice. A silicone case with a stand would be paradise though
So can we conclude that the Smudge proof invisible shield is the culprit for the slight graininess or is the screen grainy because its a 3d screen?
Nothing grainy about the screen, so - I'd question the cover if you're seeing that.
Now I'm looking for good music headphones that come with a mic. Preferably in ear headphones. Up to $25. Any recommendations????
Can you please post a link to where you purchased this?
I just bought some Yurbuds and they are amazing. They are ear buds that are made specifically for your ear. It comes with a couple different buds so you can pick which one fits best. They never fall out and I use them all the time when I run and lift at the gym.Anyone???
If any of you don't want the rubbery and orange peel look that Zagg's tend to get, you should get a ghost armor.
They finally have them available for the 3D
Just went to best buy today and they refused to take back my invisible shield or swap it for me even though the pre installed it for me. I never told them I wanted to anti-smudge shield but it still got put on when i bought the phone. Best Buy is really getting under my skin the last couple years. Use to love them until they became so anal about everything.
Does best buy sell ghost armor? Did anyone else have trouble returning their zagg invisible shield at best buy?
That's terrible! I had the smudge-free Zagg one installed by BB and they took mine back yesterday. They would NOT return the $7.99 install fee, however. But, it's a simple return that you are not happy with the product. I would think they would HAVE TO refund your money.
Wow. Did you leave it on ur phone when you returned it? Did you have the original box cuz they never gave me a box. They told me i cant return it because installed products are not eligible for return. I gotta try another best buy
I did have the box..but the guy had kept the solution. I also left it on the phone and let them remove the protector. I even took the case off, the Platinum Series, and returned that without the box. They were very nice about the return. I would go to a different BB. That just doesn't seem right. Tell them you are not happy with it and want a refund. They should give it to you less the install fee!
Hmm okay i will try that. Btw, whyd you return ur case? I also have the platinum hard case with the kick stand and havent had any problems
