Help evo3d stuck at sprint logo on startup
Stock evo3d had it since july no problems. Programs started crashing today so I did a soft reboot, now it won't load past the sprint logo at startup. Just sits there.
So far I removed the sd card and did a battery pull with no luck. What else to try?
The only thing I could think of is you will have to do a Factory Reset in recovery mode. I know your not rooted but you can get into recovery while not being rooted with a battery pull. Wait and see if anyone else has any solutions, if not then I will explain how to do so
how long are you letting it "sit there" whilst on the sprint logo?
how long did you remove the battery?
leave the battery out for 5 minutes
re insert and let the phone boot up. if its still stuck on the sprint logo, just let it ply for a few minutes... give it about 5 minutes. let it work out what could be causing the issue.
if no success, recovery may be your best bet.
I let it sit at the logo for about an hour and also tried leaving the battery out for around an hour.
My biggest thing is avoiding a factory reset as I don't want to lose the data I have on the phone.
I also fully charged the battery, if I turn it off and plug it in the charge light indicator lights like always and charges.
With the recovery option in the system menu, is there a way to load a stock rom without unlocking the phone?
No you need to be rooted for that, and all you will loose on a FR is your apps, which will download again once you sign into Gmail, as that will reinstall your apps, or you can use Titanium back up also. but you will loose all your text stored, other than that you will simply have to set your phone back up the way you had it, and you can take screen shots and have your phone back to where it was in 15 minutes. It is the only way I see to resolve your issue that I know of, I have had a few friends with the same issue and usually the FR is the only solution on a none rooted phone, if you call Sprint this is what they will make you do
Thanks for all your information.
I went ahead and did the factory reset, which did fix it. It seems I lost my text messages, contacts and installed apps.
Marketplace is reinstalling my installed apps, however my contacts didn't come back after I associated my gmail account. Looks like they are all lost.
What's the best way to backup/sync contacts incase this happens to me again?
Well the only way you would of lost your Contacts is if you only had them stored on your phone and not Gmail, if you had them stored on GMail which most of us do now a days on smart phones, they can be restored. Make sure you have all your contacts stored on Gmail
