Help Exceptionally high data usage 2.2 Foryo
kozjegyzo
Hi All,
I'm experiencing extremely high data usage 20+ MB per day after I installed Froyo. Before my daily max was 6 MB.
Has anyone experienced this behavior?
Can you suggest a data monitoring app that tells me data usage app by app? I have watchdog, and Netcounter and Netmonitor, but they are general, and cant tell me what app is doing all the mischief.
I have an unrooted HTC Desire with OTA Froyo
Here are my apps:
kozjegyzo's Apps on the HTC Desire
I live in Hungary and unlimited plans have bee abolished years ago, so I'm stuck with a caped one that get very expensive if I overrun.
All help would be appreciated greatly...
Thanks
Hi All,
Here are my apps:
Thanks
Turn Off Face Book Syncing will fix that probem according to someone else in the Motorola Droid Sub Forum!
Thanks for the reply.
Yes Facebook for HTC Sense was the data gobler.
I turned it off and everything is back to normal.
As I see this bug affects all HTC Sense UI-s no matter what device they are on
