Contacts and Email sync just fine with Exchange 2007 on my EVO 4g (latest firmware update as of 7/26/10) the problem is the calendar sync.
I can create single appointments on my EVO and they'll appear right away in the Outlook calendar. I can do the reverse in Outlook and they'll appear right away on the EVO's calendar. I can delete in both places as well.
The issue is, any appointments that seem to be reoccurring don't sync over to the evo. I see them all in Outlook, but no matter what I do, I can't sync them to the EVO. I've tried setting the sync range to "All" in the calendar settings, manually refreshing, even slightly modifying the reoccurring appointment in Outlook and saving it, but nothing helps.
Any ideas?
Any ideas?
