Lephotograhpeur
Hi,
I have set up a HTC Desire S with active sync and it is working.
My problem is, in contacts, why it does not show all the contacts on the adress global list?
You can search for users and then it finds them but when you go into contacts, it is empty. So basically, the only way to see users from active sync, is to search for them.
Is there a way to set up so that the contacts from exchange are visible in contacts?
As an example, with Iphone, you have the option to choose "Global adress list in exchange" and can then scroll up/down to see all the users.
Anyone know how to set up this to show all users from active sync, in contacts?
Thanks in advance!
Lephotographeur
Thanks in advance!
Lephotographeur
