Exchange Active Sync troubleshooting
LarsLin
Hi,
What is the easiest way to troubleshoot the Exchange Active Sync configuration on a HTC Desire? I cannot get it to work though I am using all the settings that our IT department has given me.
The setup keeps saying, check your Exchange account settings. I am not even able to connect to the mail server. I am using Wi-Fi and I have a network connection so there is no problem with that part. Can I get a trace or similar that shows if there is the credentials that are not working or what is the causing the problem?
Thanks in advance!
Best regards
Lars
Hi,
Depending on your mail server it needs to be told to allow unsupported devices. I had the same problem also with a desire. Also new to these threads but I found the answer somewhere on these forums or via google.A line needs to be added to the server system to allow unsupported devices. Do a search and forward it to your IT department. They have to reset the server afterwards but then works.
Cheers.
