cwickstylz
Ok, so I've been trying to solve this issue since starting with my first Android phone, the Hero...
I work for a large enterprise corporation & our security policies are quite strict. I have used Blackberries, Palm Pre, WinMo all successfully with my employer, but Android just does not work! Ok, yes, I've been using TouchDown & it kind of works, but only with Exchange 2003 support running, ActiveSync will not connect.
I know our policies require simple PIN & remote device wipe, so is that what is blocking me from using the built in client? I read somewhere that someone has some sort of patch they applied that tricks Exchange into thinking it is a different type of device trying for ActiveSync & bypasses the simple PIN & remote wipe. Has anyone heard of anything like this?
Any guidance would be so very appreciated! Thank you!
