Exchange Calendar Issues - Can't Edit
wiredwrx
Sorry for the several pictures attached, but they will help illustrate the problem.
This is the software version I am using on the phone. I am rooted but otherwise stock.
and
This is the version of Google Calendar I am using
I have 2 exchange accounts on my Android device. Each syncs calendar entries properly. This pic is of one of the accounts.
However, depending on the manner in which the calendar entry was entered, whether on the phone or using outlook, the notifications differs.
This entry was added using the phone. Notice the "pen" icon in the top right, which allows for editing the entry as well as the general layout of the notification.
Now notice the notification when the entry was made with outlook. It is very different, and does not have the pen icon to edit the entry.
I found the following post (https://code.google.com/p/android/issues/detail?id=13779) which seems to indicate that it is a problem with the primary SMTP address, but I removed, and then re-added the account using the exact address, and the problem persists.
I am at a loss. Anyone have any ideas. I contact my hosted exchange service, and they asked if I had updated my android software to the latest, and then said that, since they have not had many, if any, complaints about it, there was nothing they could do. Now, I am willing to live with it if need be, but I would love to correct this issue.
I tend to think it's more of a M$ factor than an android one. Seems like the dollar sign is not allowing editing and only read only from their apps.
Definitely something with my Android. I added the calendar to another Androiud phone (TBolt), and all entries were editable on that other android.
Just tried to uninstall and reinstall the calendar app, but that did not fix the problem on the first Android (Rezound)
I also noticed this on my phone. Notice the 2 different calendar icons at the very bottom
Now me thinks I need to factory wipe or try the software update for the Rezound.
Or, just live with it, unless someone else has any ideas.
