After setting up my Exchange e-mail, I've noticed that I'm going through my battery much quicker (dropped from full charge to 90% in less than 30 mins) and the battery itself is getting hot. Is anyone experiencing the same issue?
... it would reboot, load up and after a few seconds it would reboot again... thankfully a factory reset fixed everything
Solved (for now *knock on wood*)
I deleted all my email accounts, cleared my cache, then added the emails accounts again.
so far seems to be back to normal
I've finally figured out what is causing my random issues with Exchange and wanted to share here as I know others are trying to sort out the problem.
Most of the time my battery life is great but every once in awhile Exchange goes nuts and eats battery like crazy. I have alot of open ended meetings in my calendar that I do not control and most of the time I am fine so I started paying attention to my Email invites and realized that the issue is caused when I receive a Cancel notice for a meeting that I have Declined. When this happens, the Nexus seems to go into a loop of trying to remove the declined entry and it tries to sync almost continuously. It does not matter whether I hit "remove from calendar" or not in my Outlook client, the same thing happens.
The only way out of the loop is to delete my mail account and re-add it to my Nexus and all will be well until the next time I have a cancelled meeting that's already declined and then it starts all over again.
It's happened me twice in 6 months but strangely both times I was roaming :smokingsomb:. Will this be fixed in JB?
I have an S3 and started getting the same problem at the same time as connection to office 365 starting to fail (another post in the forum). I had to kill exchnage service and put the sync on manual. Then I was suprised to see some email come through without me syncing. Something is wrong with this thing
Something is wrong with this.
I had the JB update, and since then Exchange is consuming my battery.
I don't think that this is a calendar sync issue, because I'm only syncing my mail.
Now I'm trying to delete my account, and I will see.
I also notice that sometimes the battery is heat, even when I'm not using it.
By the way: what kind of e-mail are you using? I'm using hotmail. Could be a problem with hotmail servers, rather than problem with my mobile? Maybe it can't connect with server and has to try again, and again, and again.
in settings set the Mail App to only sync Exchange Mail that is 30 days old or less. on some phones i think the default setting is 14 days.
